Could you add a target boost table?
Posted: Sun Oct 03, 2010 2:11 pm
Is it possible to create a target boost table? I did opensource tuning via the tactrix cable on my subaru WRX and it has tables for target boost in addition to wastegate duty cycles by throttle position and rpm.
It is really nice because if you don't have your Wastegate duty cyles for your boost solenoide dialed in you still run the DESIRED boost level because the ECU adjust the wastegate duty cycles. Not only that but when datalogging it tells you what wastegate duty cycle you need to hit the target boost so you can change the WDC to correspond with target boost. And it helps when the climate changes because if your temp compensation tables for WDC are poorly setup you still will be close to the target boost.
It would be awsome for those that are boosted and use the hondata boost control solenoid.
I run about 6 psi on wastegate spring pressure and I don't understand why I can make my boost control duty cycle about 27 and I still get 6 psi and then making it only 30 I hit 10 psi and 35 gets me to 17psi. It's so touchy.
I don't like how such little inputs in duty cycle yields large swings in boost. 6psi gives me about 320whp and 11psi is 400whp and 18psi is 500whp so I have to be careful with it. So I just wish 80 duty cycle gave me 17psi and not 35 dutycycle. Target boost would be sweet.
Thanks for reading.
Thanks for reading.
