Need help tuning cam angles
tiger
Post by tiger »
Hello,
I am trying to tune each cam angle. I have already read a lot of posts, understand the techniques, watched the training videos. The problem I am having is that I can't get rid of the knock on a cam angle map. I started with the 0 low cam map, started WOT pull and knock started instantly at 2000 to 3500. I pulled, and added 2 degrees in that area but could not get rid of the knock. Do I just keep pulling ignition? I have attached the kal and datalog. Any help is appreciated.
Setup:
K24A2
50* VTC
CAI
JRSC 3.0 Pulley
Aftercooled
Short Header to 2.5 test pipe and mid pipe. Type R muffler.
gigaCTR
Post by gigaCTR »
Retard ign, dont add!
tiger
Post by tiger »
I pulled two degrees and it still knocked. Pull 2 more?
kornshadow097
Post by kornshadow097 »
Well you can retard ignition, but you should be using your datalogs and adjusting your fuel map first. Have you been adjusting the fuel? and keeping the A/F ratio's at the desired numbers?
If you are then I'd keep pulling the ignition numbers down until you see improvement.
El Verdugo
Post by El Verdugo »
As a member said earlier, the AFRs have to be optimized in all the operating cells and load before one can start doing the timing.
If the AFRs are good then yes pull timing until its gone.
GL
