"VTEC oil pressure switch enabled" ECU JDM
Posted: Fri Oct 01, 2010 2:58 pm
"VTEC oil pressure switch enabled" in central p08j should be activated or deactivated?
why talk like that
"For JDM engines and JDM ECU disable the VTEC oil pressure sensor."
in the manual:
http://www.hondata.com/help/smanager/in ... l?vtec.htm
If you leave your Vtec Oil Pressure sensor activated lights check engine light?
why talk like that
in the manual:
