Help With Error Codes and A:F and VTEC Controll
Posted: Thu Sep 30, 2010 9:50 pm
by 96VTi-R
Hey i just got a S300 P28 ECU and installed it with a harness into my 96 Integra VTi-R (GSR), i loaded the 93-95 GSR Base Map, because that was the closest to my car and am having a few problems.
First Off Error Codes:
20 ELD Electrical Load Detector
23 KS Knock Sensor
41 Oxygen Sensor Heater
Second Air Fuel display is constantly red
A:F (:1)
ranges from 0.7* - 0.8*
Third is, i got told by a reputable tuner that if i really want to use the s300 for now, just upload the VTiR base map and set VTEC to 5700 because I'm using the Skunk2 IM, to do this do i just adjust the lower and upper to 5700?
My Car Info:
1996 Integra VTiR, I/H/E Skunk2 IM.
Any help would be appreciated
Posted: Fri Oct 01, 2010 5:59 am
by AREA876
you can disable the codes, go to Parameter - Misc. tab. and you can disable knock & ELD sensor. Go to close loop tab and you can disable the O2 heater.
Posted: Fri Oct 01, 2010 6:51 am
by 96VTi-R
Thanks for the reply, so those sensors aren't necessary or required?
