Shift light problem - solved
Posted: Mon Sep 27, 2010 11:06 am
by retroid
I have a PRA ECU, KPro on K20A2 european Honda. I`m running the factory K20A2 calibration for now due to the stock engine.
I also have a PLX wideband connected to the ELD pin 15 with cut wire to ELD.
I soon mounted a shift light which is conected at ECU E connector pin no.26 , engine speed pulse, blue wire.
http://www.caraddiction.co.uk/sld5.htm
After connecting the shift light my revcounter stop working.....if I unplug the shift light wire from pin 26 the revcounter starts again...
al the wires are soldered so no connection problems.
(the power for shift light is cig lighter and ground to chassis)
Until now I checked everything but I didn`t find the problem.
Could this be related with Kpro? I mean some parameters changes like ELD disabled etc.
many many thanks
Posted: Mon Sep 27, 2010 4:07 pm
This has nothing to do with the K-Pro. This would be a problem with the shiftlight.
Posted: Tue Sep 28, 2010 11:51 am
by retroid
problem solved. I triple check everything and somehow the revcounter start to work!
many thanks
