S300 offline out of no where
Posted: Sun Aug 29, 2010 11:16 pm
Good evening,
I have a s300 installed and running on an old laptop with windows xp. I have been tuning my car on this setup for 3-4 years now with no problems.
Today I was checking some things and making adjustments (as I typically do). I turn off the car and the laptop. I left everything sitting as-is as went to go check the compression of my engine.
I then turn on the laptop and the car and windows prompts me with the "new hardwar found" note. And It doesn't even recognise it as a "Hondata s300 ECU" but as "USB <-> Serial" which in Windows' device manager is under a separate unknown device section rather than the usb section. So when I try to reinstall the drivers (mannualy and through the wizard) via the smanager folder it cant find the drivers for the device.
So far I have tried the following with no luck.
rebooting the computer
unplugging the battery
using the help menu driver update
installing the latest version of hondata (I was previously using 1.4.0)
using the dirver update in 1.4.7
tested my usb ports in my laptop with other devices.
So im not sure if its an ecu issue (maybe something fried after all these years) or what.
Any help is appreciated.
Thanks.
Thanks.
