A friend of mine is planning the following setup:
A T3-T4 Turbo, 6 to 10 psi on a D16Y8 (OBD2) engine
A-PEXi VAFC,
250lph/90psi fuel pump
Vortech 12:1 fuel pressure regulator
Missing link MAP sensor
He'd like to know the recommended injector size for his plans? Any help or suggestions would be greatly appreciated.
PJ
Help with injector size
Injector size
So with a 12:1 fuel pressure regulator what is the fuel pressure at 10 lbs boost? 155 psi? (base of 35 + 10 * 12) We'd recommend 440cc injectors for that setup using Hondata (without the VAFC and rising rate fuel pressure regulator).
