Safe to get reflash with cel on?
Posted: Fri Aug 27, 2010 6:40 am
by 305 DC5
My cel is throwing a o2 sensor code that controls air/fuel ratio? Not exactly sure about replacing it because I'm worried about it going bad instantly. Im running i/rh/e and have a eliminator/defouler on the catalytic converter o2 sensor. Would the reflash be ok or safe with the current set up? Would it make things better or worse with the o2 problem?
Posted: Fri Aug 27, 2010 9:26 am
A reflash will not correct a probelm that is generating a CEL. Follow the Helms manual and troubleshoot the error code you have.
Posted: Fri Aug 27, 2010 10:29 am
by 305 DC5
but if i got the reflash before taking care of the o2 sensor problem would it be ok?
Posted: Fri Aug 27, 2010 11:41 am
you can get the reflash, but you must resolve the error code.
Posted: Fri Aug 27, 2010 11:50 am
by 305 DC5
even with all the talk about the running lean or rich etc etc the ecu wont make anything worse?
