B16a2 60-1 Turbo Pte 880cc 255lph 4 bar map
M3tech95
Post by M3tech95 »
Wondering if i can get a basemap for my setup so i can drive to dyno tuner, any help would be greatly appreciated:
B16a2 stock internals
Turbonetics 60-1 A/r 70
Pte 880cc injectors
STR fuel rail
Paxton Fpr
Walbro 255 lph pump
basically looking for idle and VERY EASY driveability about 20 miles to my tuner..1lb boost cut & vtec disable is fine i have discipline lol..
Thanks for any help
"Cheap, Reliable, Fast, you can only pick two"
M3tech95
Basemap
Post by M3tech95 »
I did some searching already the closest base ive seen was http://www.hondata.com/forum/viewtopic.php?t=7101 but the link seems to be dead....
Phantomhatch wrote:The Setup:
B16a
Stock Sleeves
Victor X Intake Mani
Wiseco Pistons
Crower I Beam Rods
Block Guard
PTE 880cc Injectors
Aem fuel Rail
Walbro 255
B&M FPR
Garrett 60-1 S-cover anti surge housing
Turbonetics Evolution WG
AFI Ramhorn Manifold
ACT solid Disk
XTD PP 1900lbs
HKS SSQ
3" Down Pipe
Stock head
Total PSI was on 23lbs. This car really gets mad with 195's on th front traction im sure you can guess is not there!
This was also done on a Dynopacks as well
Total Power 424hp 283tq @ 23 psi on 93!
********NOTICE****** to whom gets this map mind you i have a 60-1 turbo 880cc injectors anda GM 3 bar map sensor.
here is the goodies
The Vid:
Image[url=http://videos.streetfire.net/video/8915 ... 24c072.htm]Lima Racing-[/img]
