deceleration fuel cutoff
ton
Post by ton »
Does the hondata s200 have a deceleration fuel cutofff. If so how do I disable this. I dyno tuned a turbo gsr with built internal with converative timing and 10.5 A/F ratio @10 PSI, but still end up frying the piston rings. I think this is due to a fuel cutoff once I decelerate and actually burning the piston.
Is there a minimun duty cycle like other aftermarket engine management.
How does the ecu know I am decelerating, through the brake signal or maybe the vehicle speed sensor. Any help appreciated.
Tony
QUICKSILVER RACING
Post by QUICKSILVER RACING »
I think the deceleration cutoff is not the problem.
The ECU will cut-off fuel when TPS VOLTAGE goes below 0.47V which is 0% throttle or you just might need to adjust TPS.
Have more than 5 turbo customers tuned. only one dynoed. All are fine except for one car that blew a radiator hose and overheated.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
