Hybrid Harnes problem with Pra Ecu
mfred-ej9
Post by mfred-ej9 »
Hi i have a 97 ek hatch and swap a european k20a2 with a pra ecu...the european ecu runs with a narrow band O2 sensor
i bought the hybrid racing swap harnes and somebody told me that the harnesses are not wired for narrow band sensors, and the UK spec engine wiring loom is pinned differently than the US spec.
can anybody tell me what i must change at the harnes to run the european ecu with the narrow band O2 sensor?
sorry for the bad english
Contact Hybrid Racing.
mfred-ej9
Post by mfred-ej9 »
i did i did... :( they said that they cant help me :cry:
the car runs but i have the error code o2 heater control...
how is the primary o2 sensor wire to the pra ecu?
mfred-ej9
Post by mfred-ej9 »
ok thanks but can you help me a little bit???
i see the primary o2 goes to pin...
A6 = Signal+
A1=heater-
and the other both???
