C Spec Cam's Flash Pro Values
Posted: Mon Aug 16, 2010 6:35 am
by okoboko
Hello Guys,
I have a Type R FN2 and, am stuck in a terrible issue and, now need your help urgently if possible. My car's specs as stated below:
Toda Spec C Cams
Toda Valvesprings
Toda Highpower Head Gasket
Since there is no loaded flashpro done in my country (Turkey), I urgently need to know Spec C Camshaft'S high cam and low cam values with specific angles on flash pro. It would be great if I can get a graph of it.
Thanks for your help in advance.
Posted: Tue Aug 17, 2010 12:27 am
by okoboko
It would also be great if any of you can give me the person's telephone number that I can talk to from Toda or from anywhere that is qualified enough to give me needed information. :roll:
Posted: Sun Sep 05, 2010 4:40 am
by CivicVTi
I've never used Toda C on stock pistons. Be careful. I would not go over 30 degrees on the high lift lobes. Low lift lobes are usually OK up to full 50 degrees but usually, you do not need more than 40.
Generally this is not a good cam for a medium compression 2.0lt engine. You must either go to 13+ with forged internals and/or increase displacement to see the benefits of these huge cams. Believe me, you will be much more happy with Toda A3's
