Reporting some issues while tuning AFM sensor
Posted: Fri Aug 13, 2010 7:22 am
by myuser
Hi,
I was tuning the AFM sensor and I notice that :
- Changing the scale in S.TRIM sensor causes the tooltip not to show correctly when the advanced graph XY is used
- Change the value in AFM flow table with Ctrl+J, enter one value for percentage and if a positive value is entered the adjustment is correct else the value adjusted is incorrect. I tried other tables and same thing happened.
The version used is 1.1.5.6 the stable version.
Thanks !
JP
Posted: Fri Aug 13, 2010 9:17 am
Changing the sensor scale works ok for me here. Can you outline the exact steps you are taking?
Percentage decreases are adjusted so that you can increase and then decrease a table value by a percentage and arrive back at the same starting point.
Posted: Fri Aug 13, 2010 12:53 pm
by myuser
Hondata wrote:Changing the sensor scale works ok for me here. Can you outline the exact steps you are taking?
The steps for the tooltip are:
- Double click in sensor list (sensor S.TRIM)
- Change the value minimum to -10
- Change the value maximum to 10
- Go to Advanced Graphs --> XY Graph
- Try to get the mouse pointer below 0% lets say 4% or 5%
- Example: Shows 'AFM.v 2.0V S.TRIM ' (S.TRIM without value)
To reproduce the percentage value I took the following steps:
- Open a "fresh" calibration. Example ( FN2 Group N reflash)
- Select a table, any table. Example (Low or High Cam)
- I selected a "round" number let's say 10 or 20.
- Hit Ctrl+J
- Subtract -50% to 10 and the same to value 20
- Should be 5 and 10 as the result value; the results are 6 and 13
Thanks!
JP
Posted: Mon Aug 16, 2010 10:40 am
The graph works correctly here. What sensors are you using for each axis? Do you need to change the values before or after the datalog is loaded?
Posted: Mon Aug 16, 2010 12:22 pm
by civicRSA
I have the same problem with the tooltip only showing positive s-trim values on the XYgraph.
Posted: Tue Aug 17, 2010 12:52 pm
by myuser
Hondata wrote:The graph works correctly here. What sensors are you using for each axis? Do you need to change the values before or after the datalog is loaded?
Ummm.. good question. I can said that I was with one datalog loaded then I open the graph XY then I switch to another datalog.
The negative values disappear in the graph on the other versions aswell. I tried set to default values and nothing changed; the tooltip is incomplete; can't revert to normal state.
Ok... try to set the S.TRIM to [-10;-1] ... the values missing are only the negatives...probably should reproduce; Then go back to default ... still missing.
The values used are S.TRIM and AFM.v (AFM tuning as explained)
