does the stock knock sensor work with k-pro
shwoogie420
Post by shwoogie420 »
hello,
i have an 02 civic d17a2 fully built k-pro version 1.3.7.0 . while doing some pulls i noticed that my knock count and knock threshold are no where near each other which is good b/c there is no knock. what i want to know is does k-pro resgister the knock with the stock sensor or is there an aftermarket one i have to buy
icebox434
Post by icebox434 »
ive been using the stock one for 6 months with no issues
When we created the base calibrations we had to disable the knock sensor as it would give error codes since the knock sensor was not for the ECU being used.
shwoogie420
i have the knock sensor enabled and it is not throwing any error codes.it is giving me readings what i want to know is if what it is reading is corect.
mixwell
Post by mixwell »
borrow a friend's knock sensor off his motor if you think yours is malfunctioning.
15/16th deep socket to get it off.
shwoogie420
the knock sensor is fine....what i want to know is that since the knock sensor is not meant for that computer are the readings they are giving me corect or do i need an rsx knock senor
shwoogie420
sooooo is that a yes or a no....looking for an adminstrator to answer this one
