b16a pct pistons std bore.
b16 head p&p hondata gasket blox manifold, omnipower 70mm tb
brian crower flat faced valves, blox springs and retainers, blox c cams
aem gears, +2 on intake 0 on exhaust stock injectors. bdl fuel rail with gauge at 55 psi
running stock exhaust currently but have 98 spec header, 2.5" no cat to 2.5" es muffler.
on s300 running off jdm p30 base map got detonation like crazy unless dizzy is retarded
anyone have a map similar to this set up?
