Whatup, I have a 90 accord set up for 30 pounds and cant find a basemap for it at all. I have it running on an h22 turbo map right now but it starts running like shit when It gets up to operating temp. Anyone out there built their f22 like I did? =)
f22b1 Sleeved block
86.0 mm 8.0 compression arias pistons
Crower H beam Rods
Port and Polished head with custom s2000 turbo profile camshaft
Bored out stock throttle body
stock vtec ignition w/ external oil cooled coil
iridium spark plugs (should I use platnum rather?) -I have had issues on my maxima with them-
Bottom end has been balanced and blueprinted by me
12 lb flywheel, 6 puck act w/springs.
t3/t4 ar .49 rear mounted turbo made partly from an STS turbo kit.
3 inch charge pipe (from the headers to the turbo in the trunk) that has been heatwraped
2 1/2 inch intake piping
Water to Air Cooler with a 2 1/2 gallon heat exchanger and 2 gallon ice box
(dont remeber exact size, but they are huge) 48mm waste gate and 58mm blow off valve. (from the STS kit)
1000 cc injectors
AEM fuel rail, aem fuel pressure regulater, 255l/h fuel pump
NOS Wet fogger 200shot
Air Bag Suspension (cause the pipes make the car have no clearance)
With the water methenal injection I will be installing soon should be able to run 30+psi on pump gas. =)....If I can figure out how to tune it..
Oh, heres the kicker too....I live in Maui and we dont have a dyno on the island....=)
If you want to see pictures look up highonmaui on facebook, all the pictures of the car are on there
Mahalo
Chani
Need help with a map for my remote turbo f22b1
Highonmaui
- Contact:
90 Accord Remote Turbo Sleeved f22b1.
