Page 1 of 2
Open loop over 5000rpm
Posted: Mon Aug 02, 2010 6:12 pm
by XPEHODATA
SManager 1.4.7.0 and 1.4.8.0
Why S300 switching to open loop from 5000rpm with any MAP and TPS values?
Posted: Tue Aug 03, 2010 9:26 am
Posted: Thu Aug 05, 2010 9:01 pm
by XPEHODATA
B16A2
P30 ECU
Skunk2Stage2 Cams
LC1, narrowband connected to D14, wideband connected to D12
Symptoms affected with narrowband closed loop and wideband closed loop
When >5000rpm - s.trim=0
Posted: Fri Aug 06, 2010 2:08 pm
This is normal operation for it to go into open loop at that RPM.
Posted: Fri Aug 06, 2010 2:17 pm
by XPEHODATA
Spunkster wrote:This is normal operation for it to go into open loop at that RPM.
WHY???????
It's not normal!
Posted: Fri Aug 06, 2010 2:36 pm
This is normal behavior. What makes you think it is not?
Posted: Fri Aug 06, 2010 2:53 pm
by XPEHODATA
Hondata wrote:This is normal behavior. What makes you think it is not?
It's my normal cruising speed and rpm. I driving my car everyday more than 5000rpm for a long time. What a difference between 3000rpm or 6000rpm to forced open loop? Why I can change maximum MAP/TPS and can't change max rpm for this???
I have Golf GTi 1.8 turbo. That ECU always in wideband closed loop from factory. And have more than one targed voltage for it for some MAP values.
Posted: Fri Aug 06, 2010 3:05 pm
by newsoltsc
Are you always racing your car? I never reach 5k rpm when I drive unless I'm either racing; or accelerating to pass somone.
Posted: Fri Aug 06, 2010 3:16 pm
by XPEHODATA
newsoltsc wrote:Are you always racing your car? I never reach 5k rpm when I drive unless I'm either racing; or accelerating to pass somone.
No. It's my everyday car. What a problem for 5k? I have vtec point at 6800rpm and rev.limit at 9000rpm. And driving my car more than 100ml/h at highway for a long time. It's a Honda.
Posted: Sun Aug 08, 2010 8:28 am
by megomaniac
gear ratio change? what transmission do you have?
Posted: Sun Aug 08, 2010 9:05 am
by XPEHODATA
megomaniac wrote:gear ratio change? what transmission do you have?
Stock transmission with 4.4 final gear. Max speed 220km/h @ 8500rpm
I have a transmission with KAAZ 4.9 final gear and Carbonetics 1-5 gears for racing. Max speed 170km/h @ 8500rpm
The car worked perfectly about 5 years. I don't wont changing anything in the car. I just want true closed loop. And not understanding - why it's normal when ECU goto open loop at 5000rpm.
Posted: Tue Aug 10, 2010 6:45 am
by VT-Doo
If it's normal behaviour what should the air/fuel ratio be?
Does K-Pro do the same thing and if so the same question as before; what should the air fuel ratio be? :?
Re: Open loop over 5000rpm
Posted: Thu Aug 12, 2010 12:20 pm
by jetspeedz
XPEHODATA wrote:SManager 1.4.7.0 and 1.4.8.0
Where did you get 1.4.8 from? i don't see a link and as far as i know 1.4.7 is latest. A link would be appreciated to post about updates.
thanks
Posted: Thu Aug 12, 2010 12:53 pm
Posted: Thu Aug 12, 2010 1:05 pm
by jetspeedz
Is there a post that states the updates and difference between the new and old verison?
