P062F Code
Posted: Mon Aug 02, 2010 7:25 am
by pando
Hi,
Last night i did a return to stock on my ECU and got the code P062F Internal Control Module EEPROM Error.
Anyone knows what does it means??
Thanks,
Posted: Mon Aug 02, 2010 10:03 am
What version of software are you using from Help, About?
Posted: Mon Aug 02, 2010 12:33 pm
by pando
I'm Using Ver. 1.1.5.6
Posted: Mon Aug 02, 2010 4:31 pm
What is the code on your ECU?
Posted: Mon Aug 02, 2010 8:30 pm
by pando
Check Engine light comes on and under Error Codes from a datalog on Flashpro it says "P062F Internal Control Module EEPROM Error"....car runs normal and nothing sounds or feel different...
Posted: Tue Aug 03, 2010 9:27 am
But what does the sticker on the ECU say?
Posted: Wed Aug 04, 2010 5:25 am
by pando
RRB-A14???
Posted: Wed Aug 04, 2010 10:10 am
What happens when you upload a different calibration?
Posted: Wed Aug 04, 2010 2:46 pm
by netinfosolutions
In my car happen the same thing ....
When I upload a tunned map the check engine flashs 5 times. Anyone can help us?
Tks!
Posted: Wed Aug 04, 2010 3:07 pm
If you go to Online and click on Clear DTCs does the error go away?
Posted: Thu Aug 05, 2010 5:23 am
by pando
Thats what I did, called a friend whos a technician at a Honda service center here and he told me the procedure they do.....They clear the DTC and check if it comes back, if it does, they change ECU and check again if nothing then its a bad ECU. If you clear the DTC and never comes back then it was probably a bad reading, nothing to worry about.
Mine is all clear now, thanks!
