1.9ls/vtec ign timing
nalsv
Post by nalsv »
wondering why my tuner did this with my high speed timing table??? any input?
is your engine boosted?
nalsv
Post by nalsv »
no its NA
don't look at the boost colums since they are not used.
allm0t0rGSR
Post by allm0t0rGSR »
is it tune on the dyno? and what is the spec of you engine?
nalsv
Post by nalsv »
yes dyno tuned ls vtec 13.5 compression 82mm b16 head with work bumpstix rdx injectors 237whp ok so thx for that info
nalsv
Post by nalsv »
spunk i dont know how boost side works but the hump looks like its under full vac not boost
Then you will need to discuss this with your tuner if you feel they did not tune the engine correctly.
allm0t0rGSR
hey bro can u post all you moods on yur engine bcoz it seems we have the same set up..
thanks
nalsv
Post by nalsv »
BASICLY 13.1 COMP PISTONS, ENDYNE BUMP STICKS, ENDYNE HEAD WORK,PORTED BLOX INTAKE MANI, RDX 410CC INJECTORS
