We are getting a code 13(Baro-Atmoshperic pressure sensor) and 16(injectors) after installing hondata.. The ECU is a P28. Hondata is a S200 with boost. Without the jumper, there are no codes at all..
Could I have a bad basemap? Can and should the baro be disabled if a new rom is burned? This isn't common with P28's is it? Thanks for any help you can give. We are hoping this can get resolved.
Nate
Code 13 and 16 after hondata install
5thgencivic
