Vtec6000
Posts: 43 Joined: Sun Apr 18, 2010 5:47 am
Post
by Vtec6000 » Fri Jul 23, 2010 4:01 pm
Can anyone tell me what error message you get if you try upload map off a ecu which has been "set security"?
Posts: 24182 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Jul 26, 2010 9:27 am
What exactly is happening?
Vtec6000
Post
by Vtec6000 » Tue Jul 27, 2010 6:36 am
Can't remember 100% what the message was but it said something like access violation of some module, it would read almost to the end then stop and a window would pop up saying the above. Is that the map locked?
Posts: 10652 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Tue Jul 27, 2010 7:56 am
If you're trying to download from the ECU close all windows in KManager.
Vtec6000
Post
by Vtec6000 » Tue Jul 27, 2010 8:06 am
Yeah I had nothing open man, just launched kmanager and tried uploading. Does anyone know the exact message which appears if you try upload map from a ecu which has had security set? Also the s300 lead is same as kpro lead correct?
Post
by Spunkster » Tue Jul 27, 2010 1:35 pm
From Help, About, what version of software are you using?
Vtec6000
Post
by Vtec6000 » Wed Jul 28, 2010 5:12 am
@Spunkster, its version 1.4.0.0 feb 2010....
Post
by Spunkster » Wed Jul 28, 2010 4:52 pm
Post the calibration you are attempting to upload. What happens if you click on New Calibration and upload one of the calibrations there?
Vtec6000
Post
by Vtec6000 » Thu Jul 29, 2010 3:03 am
Sorry I'm probably saying this wrong what I'm trying to do is copy the map
that is currently on Ecu into kmanager so I can tweak the current map on there
Post
by Spunkster » Thu Jul 29, 2010 9:19 am
IF it will not work, then your only option is to upload a new calibration to the ECU instead and overwrite whatever is in there.
Vtec6000
Post
by Vtec6000 » Thu Jul 29, 2010 11:54 am
So its more than likely locked? By the way what is the correct base calibration to use for a jdm import DC5 integra?
