Changing Rev Limits from Hondalogger
Posted: Fri Jan 16, 2004 5:16 pm
by CivicVTi
I have an s200 on a P30 ECU with datalogging enabled. I can't change the VTEC point from Hondalogger or palmlog. When I hit the update button, values return to the previous ones.
Posted: Mon Jan 19, 2004 3:42 pm
This is because you have the vtec point set in the ECU. If you want to be able to change the vtec point, you must burn a new eeprom with no vtec point set in the rom.
Posted: Tue Jan 20, 2004 3:02 pm
by CivicVTi
But I haven't selected fixed vtec revs in ECU. Double checked it!
Posted: Thu Jan 22, 2004 3:09 pm
There is no update button in Hondalogger, you simply change the value and then it is changed.
If you still feel there is a problem, please email your ROM image to
support@hondata.com discribing the problem.
