Changing Rev Limits from Hondalogger
CivicVTi
Post by CivicVTi »
I have an s200 on a P30 ECU with datalogging enabled. I can't change the VTEC point from Hondalogger or palmlog. When I hit the update button, values return to the previous ones.
This is because you have the vtec point set in the ECU. If you want to be able to change the vtec point, you must burn a new eeprom with no vtec point set in the rom.
CivicVTi
Post by CivicVTi »
But I haven't selected fixed vtec revs in ECU. Double checked it!
There is no update button in Hondalogger, you simply change the value and then it is changed.
If you still feel there is a problem, please email your ROM image to support@hondata.com discribing the problem.
