Page 1 of 2
Starting the engine
Posted: Wed Jul 21, 2010 1:20 am
by Itsuki
Hi,
I have a problem when I try to start the engine. Now, I have a Rotrex C30 supercharger with 750cc RC and the car doesn´t start.
It´s a bit weird because the MAP sensor it´s the 4 bar from you (Hondata) and with the engine off, it shows a 230mBar of pressure in the intake manifold (seems ok, like vacuum). But if I put the stock ones, (and select it in the calibration), it shows a value of ambient pressure 930mBar.
But with the stock sensor the car can start. It has a doubtful idle, and after 5 seconds the AFR goes to lean quickly ( that´s when I stopped the engine).
I don´t know if the sensor it´s faulty, and I don´t know why can start with one sensor and not with the 4 Bar. Because the calibration it´s the same for both except selecting the sensor.
What can I do to make it start? I tried to add and remove fuel in the field "cranking fuel trim" but it doesn´t make anything.
The calibration it´s the inital map form TTS performance. I´ve attached the calibration. The only thing I did, was change the size injectors to 750cc and select the 4Bar MAP sensor.
Thanks for the help.
Posted: Wed Jul 21, 2010 9:40 am
Did you change the MAP sensor type to stock when you put the stock MAP sensor in? If not, do this and datalog a couple of seconds of cranking.
Posted: Wed Jul 21, 2010 10:56 am
by Itsuki
Hondata wrote:Did you change the MAP sensor type to stock when you put the stock MAP sensor in? If not, do this and datalog a couple of seconds of cranking.
Yes, I changed the sensor type according to the sensor was put on it.
When the MAP sensor type was crossover with the MAP sensor, it showed a very low value 20mBar and in the other case 2 Bar aproximately.
What do you suggest to do?
Thanks.
Posted: Wed Jul 21, 2010 3:34 pm
by nunoctr
what version of flaspro manager are you using?
download the last version from this site and afer upload again the calibration to the ecu.
Posted: Thu Jul 22, 2010 2:16 am
by Itsuki
nunoctr wrote:what version of flaspro manager are you using?
Ok, I´ll try the latest one.
Posted: Thu Jul 22, 2010 5:41 am
by civicRSA
Firstly your fuel tables as well as the cranking fuel tables look very lean.
Secondly what is the brand of your 4bar sensor? I suggest you get a Hondata 4bar sensor
Posted: Thu Jul 22, 2010 6:42 am
by Itsuki
civicRSA wrote:Firstly your fuel tables as well as the cranking fuel tables look very lean.
The MAP sensor it´s from Hondata.
Where did you saw the cranking fuel tables? Because the only thing to modify the cranking fuel that I saw, was the cranking fuel trim.
Thanks.
Posted: Thu Jul 22, 2010 8:35 am
by civicRSA
If you look in the calibration window. Look under fuel there will be a cranking fuel table.
Where did you get that calibration from?
The fuel looks even to lean for a NA motor.
Posted: Thu Jul 22, 2010 9:02 am
by Itsuki
civicRSA wrote:If you look in the calibration window. Look under fuel there will be a cranking fuel table.
It´s a base calibration from TTS. I knew that I had to optimize the map, but at least it would started.
I think that my FPM version (1.1.3) it´s a bit old.
These days I´ll post any advance on it.
Thanks for the response.
Posted: Thu Jul 29, 2010 1:57 am
by Itsuki
Another issue here. I´ve lost the Flashpro, and a friend of mine lent me
his FP to try to move the car. He returned to stock his car, but when
I plug in my car and try to lock the FP shows the message that contains an unrecognized calibration. And adds the calibration ID 'CIV-SI-RC-1131'
What can I do? Because I ordered another FP, but I need to unlock the ECU from my lost FP.
Posted: Thu Jul 29, 2010 11:12 am
Download the most recent version of software from our website.
Posted: Thu Jul 29, 2010 3:54 pm
by Itsuki
Spunkster wrote:Download the most recent version of software from our website.
The issue with the locked FP was with the 1.1.5.6. I couldn´t try to start again the car with the new version, because I lost it before I updated the FPM.
Thanks.
Posted: Fri Jul 30, 2010 10:38 am
Post the claibration you have uploaded in the ECU.
Posted: Sat Jul 31, 2010 8:57 am
by Itsuki
Spunkster wrote:Post the claibration you have uploaded in the ECU.
The calibration that I tried to upload was the same that in the first post (a
few mods on the fuel and cranking).
Finally I put the other ECU that i have (the stock ones) to continue
working on the car.
Here´s a datalog with the stock sensor. Look how it becomes leaner after a
while.
Posted: Mon Aug 02, 2010 1:26 am
by Itsuki
At last, the car started. I had to upload a new base calibration for 750cc injectors and adjust a little bit the cranking table. Now I have a leak in the intake manifold because it´s not compatible with the Hondata gasket.
Tonight I´ll upload some datalogs. The idle it´s always moving, but I think it´s the leak.
