Civic Type R from Romania , need help!!
Posted: Thu Jul 01, 2010 4:48 pm
by sandrei
Hey guys, i am running a Euro Civic Ep3 K20A2 with : Aem Cai ,Dc RH 4-2-1 , Invidia n1 Catback , Skunk2 Pro Series Intake MAnifold ,SKunk 2 Pro Series Intake Throttle Body 70mm, Hondata Kpro with PRB ECU.
My car has been mapped , but at part throttle between 2k and 3k , my car is not accelerating smoothly, it's bouncy , but when accelerating harder it is accelerating ok beetween 2k and 3k...Here are some datalogs that i made, maybe you can please look at all of them and tell me if the map is corectly done...:)
Also i was running in closed loop after the car was tuned for about 500km , and the p0134 error flashed my mil light.
I disabled p0134, and a short while after the p1167 flashed my mil light, so i disabled that also, reading the next help from the hondata help :
"Disable P1167 and P0134 DTCs for race vehicles without a primary oxygen sensor."
But the problem is that i am using a primary oxigen sensor a Denso Wideband...is it toasted? what can i do?
Now i a running my car in open loop until we figure it out, following the setup made for the map
Posted: Fri Jul 02, 2010 7:58 am
You should never disable the P1167 error when running closed loop - this error means something is wrong with the o2 sensor. Also the short term fuel trim is set up to only add fuel, never subtract.
In the datalog I can't see where your having trouble. Do you have a time in the datalog where you're hacving trouble? Also the datalog is in open loop from the o2 sensor error.
Posted: Fri Jul 02, 2010 11:36 am
by sandrei
I have read the hondata forum and saw that a lot of members have this problem between 2000-3000k as the car hesitates for a fraction of a second. in the city is extremely annoing. it's related to the tps ignition retard, as hondata kpro has that option to remove that bug,bu it seems we cannot find good parameters to remove this hesitation.
Now running in open loop with 02 sensor heater and 02 sensor response disabled, cause it seems my wideband is toasted. I will be runnig like this until new wideband comes
