K20A2 Calibration required
Posted: Tue Jun 29, 2010 8:57 am
by a2k00
Hi, Im new to having a KPRO and would like to add a map to it.
I have a UK 2002 Honda Civic Type R K20A2
AEM CAI
Spoon N1
Spoon B Pipe
Spoon Flywheel
Stage 3 Clutch
Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
Please can someone help? Many thanks
Posted: Tue Jun 29, 2010 9:15 am
We do not recommend editing the calibration files manual or changing the ECU type.
Posted: Tue Jun 29, 2010 11:58 am
by a2k00
Spunkster wrote:We do not recommend editing the calibration files manual or changing the ECU type.
Thankyou for replying, Please can you advise why that is? From the CTROC ive been advised to load the "coid air map" and change to UK ECU, Please can you advise? Sorry for the noobish questions, Many thanks
Posted: Tue Jun 29, 2010 1:58 pm
by gigaCTR
because there are some parameters not completely identical.
Posted: Tue Jun 29, 2010 10:58 pm
by chimp
ight click k20a2-rsx-coldair and select "open with" and choose notepad then change the ECU type from 3 to 2 and click file>save in notepad. :lol:
Posted: Wed Jun 30, 2010 1:41 am
by a2k00
ok... so will the "k20a2-rsx-coldair" map be fine as it is running on a UKDM K20A2 with my mods?
Posted: Wed Jun 30, 2010 6:09 am
by gigaCTR
Read above. Will run, but its not recommended.
Posted: Wed Jun 30, 2010 7:08 am
by a2k00
gigaCTR wrote:Read above. Will run, but its not recommended.
Ok, Can you advise me as to what is recomended please?
Re: K20A2 Calibration required
Posted: Wed Jun 30, 2010 10:54 am
by rikitaun
open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....
Posted: Wed Jun 30, 2010 10:56 am
by keto06
That sounds like your best option...
Posted: Wed Jun 30, 2010 11:29 am
by a2k00
Im really sorry im a compleate noob to this, where do i get the cals? Have you got a screenshot to explain what you mean? Many thanks
Posted: Wed Jun 30, 2010 2:39 pm
by gigaCTR
menu - file - open
destination is ..\your kmanager folder\Calibrations
Posted: Thu Jul 01, 2010 11:09 am
by rikitaun
jajajaja... ok men.. I try it...
Posted: Thu Jul 01, 2010 3:21 pm
by a2k00
rikitaun thank you very much, Using the map as it is will be fine on a UKDM K20A2?? Many thanks once again :)
Posted: Sun Jul 04, 2010 10:52 am
by rikitaun
a2k00 wrote:rikitaun thank you very much, Using the map as it is will be fine on a UKDM K20A2?? Many thanks once again :)
yes men,
In Spain we have several cars running so
only check the A/F values.
