confuse over cam angle
Posted: Sun Jun 27, 2010 7:56 pm
by mugen715
hi,
i'm confuse over the cam angle in the k-pro. Is 0 degree cam angle mean the camshafts is retarded to 0 degree BTDC? is 50 degree cam angle set in k-pro means the camshafts is 50 degree BTDC? could any one gives explanation?
jonathon :?
Posted: Mon Jun 28, 2010 11:12 am
50 degrees of cam advance is only 25 at the crank.
Posted: Tue Jun 29, 2010 1:59 pm
by gigaCTR
you are mixing ignition advance and cam angle degrees.
cam rotation has nothing to do with piston position.
Posted: Tue Jul 20, 2010 9:42 pm
by mugen715
hi gigaCTR.. So what does the cam angle mean? Can i just simply advance the cam angle to get horsepower? How much advance can i actually go for an aftermarket camshafts?
Posted: Sun Jul 25, 2010 1:31 pm
by gigaCTR
The cam angle is the intake cam advance measured in crank degrees. The allowable cam angle range is from 0 to 50 degrees.
The intake cam is positioned by an electro-hydraulic mechanism, which uses feedback from the intake cam position to alter the position of a solenoid which in turn rotates the intake cam inside the cam sprocket. Because of the design of the mechanism there is a delay between setting the cam position in the ECU, and the cam physically rotating to this position. This delay is around 0.1 seconds per 10 degrees of rotation.
Warning:
With Honda cams there is a physical stop limiting cam advance to prevent valve to valve contact and valve to piston contact. With after market cams it is up to the manufacturer to ensure that the cam lobes are positioned so that valve to valve and valve to piston contact is not possible. Because the cam control mechanism uses a closed-loop feedback system, limiting the cam position in the ECU will not guarantee that the cam position will not exceed what is set in the ECU. Because of this all cams must have a physical stop to prevent valve contact.
http://www.hondata.com/help/kmanager/index.html
