Wideband Wiring
spoonskywalker
Wideband Wiring
Post by spoonskywalker »
Hi...
I got ELD error after installing the PLX WB. Should I cut the wire from ELD and just connected the WD input from PLX WB only?? Currently I jumper the wire from PLX WB to the D10 (ELD) pin.
spoonskywalker
Wideband Wiring
White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU) <-- you mean, I have to cut the original wire? Sorry, a bit confused here...
Thank in advance
yes
spoonskywalker
Done.. I follow the wiring as per instruction but still got the ELD error when I did datalog. Any ideas?
In Misc Parameters, disable the ELD error.
