Posted: Tue Jun 22, 2010 1:58 pm
Fix the IAT sensor first. Without it, the cam will never advance. This may also cause more knock noise than usual.
Posted: Wed Jun 23, 2010 9:18 am
Your cams are probably installed incorrectly. Check them to make sure tehy are not off by a tooth.
Posted: Sun Jul 04, 2010 11:02 am
by rikitaun
we had the same problem with a civic rally car
the piece had a slight internal clearance
(la pieza tenia una ligera holgura interna)
Check again the VTC....
Posted: Wed Jul 14, 2010 10:49 am
Put the stock cams back in and see if the problem goes away.
Posted: Mon Aug 30, 2010 7:49 am
by rikitaun
J0aquin wrote:by now, all the sensor were changed, the car is working normally, the problem about the cams is solved
what was the problem ??? :roll:
what sensor ??
Posted: Tue Aug 31, 2010 7:13 am
by rikitaun
J0aquin wrote:i changed the whole sensors for brand new and also did a mod in the vtc actuator, i guess it was what u told me, a little light between the actuator and the cam
ok, men
eres español ??? te voy a meter como me tengas escribiendo en ingles jajajaaj
Posted: Sun Sep 05, 2010 7:31 am
by rikitaun
J0aquin wrote:jajaja, pues no exactamente español, pero si soy de mexico jeje, asi que pues tambien hablo español, pero si, como ves?? ya se resolvio el problema, tendras tu alguna calibracion que me pueda servir? Gracias
joder se agradece encontrar alguien a quien entender jajjaajajaja
te manndo por privado un regalo ;)
Posted: Sat Sep 11, 2010 9:09 am
It looks like your idle is too high because of a vacuum leak.
Posted: Mon Sep 13, 2010 10:49 am
You must fix the vacuum leak, wherever it is.
Posted: Wed Nov 17, 2010 3:16 am
by chris2000
Hi, i'm having same p0341 code after i upgraded my skunk2 stg1 cams to stg3.
Check the cam timing and it is correct but still throwing the code. what and where u mod to help? please can send pictures so i can understand better?
