K20A2 Problems
Fix the IAT sensor first. Without it, the cam will never advance. This may also cause more knock noise than usual.
Your cams are probably installed incorrectly. Check them to make sure tehy are not off by a tooth.
rikitaun
Post by rikitaun »
we had the same problem with a civic rally car
the piece had a slight internal clearance
(la pieza tenia una ligera holgura interna)
Check again the VTC....
Put the stock cams back in and see if the problem goes away.
rikitaun
Post by rikitaun »
J0aquin wrote:by now, all the sensor were changed, the car is working normally, the problem about the cams is solved
what was the problem ??? :roll:
what sensor ??
rikitaun
Post by rikitaun »
J0aquin wrote:i changed the whole sensors for brand new and also did a mod in the vtc actuator, i guess it was what u told me, a little light between the actuator and the cam
ok, men
eres español ??? te voy a meter como me tengas escribiendo en ingles jajajaaj
rikitaun
Post by rikitaun »
J0aquin wrote:jajaja, pues no exactamente español, pero si soy de mexico jeje, asi que pues tambien hablo español, pero si, como ves?? ya se resolvio el problema, tendras tu alguna calibracion que me pueda servir? Gracias
joder se agradece encontrar alguien a quien entender jajjaajajaja
te manndo por privado un regalo ;)
It looks like your idle is too high because of a vacuum leak.
You must fix the vacuum leak, wherever it is.
chris2000
Post by chris2000 »
Hi, i'm having same p0341 code after i upgraded my skunk2 stg1 cams to stg3.
Check the cam timing and it is correct but still throwing the code. what and where u mod to help? please can send pictures so i can understand better?
