Idle Quality with 370cc injectors and NA B16A
CivicVTi
Post by CivicVTi »
Does anyone has experience with this setup. THe reason I want these injectors in my NA b16a is because I'll be running nitrous through my s200. Can the motor idle perfectly at 750rpm? Or should I go with 310ccc and higher fuel pressure?
DaX
Post by DaX »
Not running that setup, but an idea would be to use the 370's and if it doesn't idle good, set the target idle to a higher RPM.
shinociv
Post by shinociv »
I am running a B16a with 550cc injectors, High compression and Skunk 2 stage 2 cams. Idle is great no problems at 750. I tried 650 once and wouldn't recommend it :D .
CivicVTi
Post by CivicVTi »
Why do you use so large injectors? Do you run nitrous?
shinociv
Post by shinociv »
Right now i rev to 10,000 and i plan to do more to my engine later.
