Question about calibrations...
Tincho_SI
Post by Tincho_SI »
Hi... i`m new... I have a 2010 civic Si with aem short ram, thermal space-bar, stock header whit the rest in 2 1/2" and hondata... I use this calibration: aem sri, rece header, highflow cat, stock catback... My doubt is the following one: Is it possible to change the advance of the ignition and the advance of the camshaft? In withc tables I have to change the values? Thanks for your help...
The FlashPro is a fully tunable system. I would recommend reading some of the traning material at
http://www.hondata.com/flashpro_civicsi_training.html and
http://www.hondata.com/help/flashpro/index.html
Tincho_SI
Post by Tincho_SI »
Thanks for your answer, now, with the stock camshaft and stock internals is it a suitable to tune the ignition and the camshaft?
I don't understand your question.
Tincho_SI
Post by Tincho_SI »
should modify the ignition and cams with the hondata???
