K20Z with RC750, car won't start
Kasander
Post by Kasander »
I'm fairly new to Hondata but I've saw alot of post and I did the right change to at least get the car started.
I went in Fuel trim and changed the injector size to 750cc.
I know the car might idle weird or die but it should at least start, it doesn't.
I tried to datalog the startup process and I see the IDC going to 2%, INJ slowly decrease in MS but the weird part is we have random IGN and it's only a brief spike of 5 degree.
I've saw a description of the car "Startup process" in the FlashPro help there:http://www.hondata.com/help/flashpro/in ... g_fuel.htm
They say the car should go for a fixed ignition of 5 or 7 degree but their timing line is flast until the car start a few ms later but in our case it's only a spike to 5 degree and 0 right after. The spike is random, we don't see the 5 degree every attempt.
Any idea what might be the problem and is the starting process the same (I guess it should)?
Note that the car got a supercharged and ran fine before the injector swap.
Thanks!
You havne't said what the problem is.
Fulll description of what has been done to the car and the calibration you are using and datalogs showing the problem are needed.
