Problems with ligths on
perico_asesino78
Post by perico_asesino78 »
Hi, I have problems with idle if I put the lights ON the wideband read LEAN and the car dont have a smooth idle.... I think that the dead time is the problem, but the precision turbo injectors had a specific dead time but if you use a resistor box... is the same dead time or not?
thanks
You must use a resistor box or you will damage the ECU. You may not have the correct dead times for those injectors.
perico_asesino78
Spunkster wrote:You must use a resistor box or you will damage the ECU. You may not have the correct dead times for those injectors.
Thanks! I have a resistor box for a prelude 90's buy I don't know what dead time to use...
perico_asesino78
the resistor box was installed with the s300 and the precision turbo injectors
