Need How To Instal S300 to P30 USDM
HeitorVTiBR
Post by HeitorVTiBR »
Hello, I am Brazilian, I have a 1993 VTi Turbo ... recently got a S300 and I wonder if there are how-to available to install the S300 on my central p30usdm ..
would like a topic and descriptive with pictures and everything .. if they can help me, thanks!
Engine: B16A2 Boosted!
HeitorVTiBR
My central socket is already using Crome or ectune for example ... I'll have to change much?
In addition to removing the plugs for the 29c256 chip or 27C256 and the cables to the datalog hulog?
well, just switch to male pins?
'll just have to do it?
I am not able to understand very well the manual posted above.
thanks
you should only have to add the 4 pin CN2 connector and switch the socket to male pins.
HeitorVTiBR
so my core is already correct socket? ja ja that used crome chip 29c256 ...
I then just add the male pins where would a crome chip for example, and the 4-pin male CN2, correct?
thank you.
Just follow the instructions. If you are not sure what needs to be done after reding them, I would suggest you have someone familiar with ECU socketing do it for you. We also offer this service.
http://www.hondata.com/ecusocketinginfoform.html
HeitorVTiBR
Next, thanks for the info above ...
today was my S300, but came to p30jdm s300j that is ... I have to install this on my s300j p30usdm (which is the same p28)? Do I have to buy a jdm p30? or return the s300j and ask for an S300?
thanks!
You cannot install a s300j into a US ECU or a s300 into a JDM ECU.
