02 RSX Type-S Need pointers on further tuning of Cams
Posted: Mon May 24, 2010 2:50 pm
Mods:
*fidanza flywheel on the tranny
*AEM V2 intake with custom apexi filter and heatshield
*Nology hotwire sparkplug wires with capacitors,
*Custom exhaust, Cat to atmosphere with a Y pipe to the stock exahust, with a buttefly valve to regulate backpressure realtime.(muscle car trick)
*Hondata intake low heat transfer gasket
*Hyper ground system
Goal:
I have been tuning the ignition, compensating fuel (temp comp too)with my datalogs, and adjusting backpressure. The only thing i havent done is change the Cam angles, which I dont know where to start since I have never dynoed and dont know what the goal would be... since ignition advancing is all based on knock count (which ive done tuning by each table/angle rather than all tables at once) and i hardly have any knocks after recent tunings.
I've reached the point where my advancing in ignition is above 50 Deg, so I think this is as good as it gets without changing the cam angles. also I dont think being that high in ignition is safe...
As well as Open versus Closed loop options... it says to use open while tuning... but does this mean dyno or datalog? im assuming dyno.
I'm not new to cars or inventing and testing technological innovations with cars, but I am a bit new to tuning cams and a k-pro (trial and error for about a year).
Goal:
