2.85v / 0.3Hg / 1002mb MAP....What the?!?!
crxluv2
Post by crxluv2 »
Brand new OBD0 build. GSR block, pr3 head, toda c's, skunk2 intake manifold in an 89 CRX Si... The engine runs extremely rich and I have the following readout in my hondalogger 2.85v / 0.3Hg / 1002mb MAP at idle....What the?!?! I have watched the example recording and my numbers are very different. My TPS reads 0.45v at idle.
I have tried another MAP sensor and I am getting the same result.
What could cause this exactly.. I believe a misplaced vacuum hose could be the result but I have screwed around with them for a good 3 hours straight and no combination seems to provide the correct results on my logger.
Any suggestions?
crxluv2
Post by crxluv2 »
Misplaced vacuum line from the throttle body caused this problem. Replaced and everything seems to be working as intended.
