Fuel map problem with last version
Garrett_si
Post by Garrett_si »
Saturday I had to tune a S2000 2001 comptech supercharged
750 cc injectors
255 lph fuel pump
Hondata s2000 kpro
watercooled system
I resized the injectors, and want to adjust the fuel map tables, it has no effect
I made an overall fuel trim to adjust it, the part throttle and idle were correct
but when at WOT the 4000-6000 rpm power band was lean, I tried a lot of adjustement in the fuel map, without any effect
I erase the ECU 2 times, and rewrite
I use an old version 1.3.7.0, and I was able to tune the car completly
I attach the cal, and the datalog when it was lean. the wideband used is a PLX M200 wiring to the ELD pin
the car is fully tuned, and everything is fine for me, but the last version don't work on this car
You have lower values in the high cam than you do the low cam at your vtec transition.
Garrett_si
Spunkster wrote:You have lower values in the high cam than you do the low cam at your vtec transition.
there is something weird
I opened map create with 1.4.0, that I set the fuel value in vtec map to 20000
and now the values aren't the same that I set saturday
really weird
