I want to know if it's me or if there is a problem ...
Hooked a LC-1 on my car:
12V on ecu mainrelay
all grounds on ecu multiground
0-5v signal is on the factory o2
All connection were made directly on the ecu harness wires
Car is 97 del sol with 96 jdm itr engine with bolt on
p28+s300+obd2a to obd1 harness
Everything work, I can datalog and display my AF on smanager but it look pretty slow.
Exemple when I let off throttle it take time to the smanager to display 18.79AF and it take time to display the normal AF when I repress accelerator.
I would appreciate if someone take a look at those attached file and tell me if the reaction speed of my wideband is not normal.
Attached is a
datalog, normal usage and shifting
my map (stock everything hondata ITR map but run 290cc and disabling some error code, I'm also in open loop in my datalog)
A picture of my wideband setting
Tell me if their is something wrong ...
ps: i know I run rich on this map but I want everything to work before tuning.
S300 + Inn0vate LC-1, slow reading ?
Untengijutsu
