afx wideband
Posted: Mon May 03, 2010 9:15 pm
by cardinalredeg
Can somebody please tell me how to intergrate the AFX WIDE BAND with my kpro ? my AFX wide band has a yellow and brown wire i believe the yellow wire is a signal output not sure wat the brown is ? I have to check but is it as simple as finding my o2 pin on the engine harness and i believe it gets a hot and ground any help would be awesome thanx !
Posted: Tue May 04, 2010 7:53 am
by kb58
You really need to come at this the opposite direction. Contact AFX for their wiring codes, then connect it up. Just guessing can blow stuff up.
hey
Posted: Tue May 04, 2010 3:30 pm
by cardinalredeg
a friend helped me out i figured thanx
Re: hey
Posted: Mon Jun 14, 2010 2:21 pm
by chemik
cardinalredeg wrote:a friend helped me out i figured thanx
so is the ecu able to use the signal for lean protection and running closed loop? I read elsewhere that it wouldnt. You ran brown to a ground and yellow to the ELD pin correct?
