afx wideband
cardinalredeg
afx wideband
Can somebody please tell me how to intergrate the AFX WIDE BAND with my kpro ? my AFX wide band has a yellow and brown wire i believe the yellow wire is a signal output not sure wat the brown is ? I have to check but is it as simple as finding my o2 pin on the engine harness and i believe it gets a hot and ground any help would be awesome thanx !
You really need to come at this the opposite direction. Contact AFX for their wiring codes, then connect it up. Just guessing can blow stuff up.
Mid-engine K24 turbo Locost, http://www.midlana.com
cardinalredeg
hey
a friend helped me out i figured thanx
Re: hey
so is the ecu able to use the signal for lean protection and running closed loop? I read elsewhere that it wouldnt. You ran brown to a ground and yellow to the ELD pin correct?cardinalredeg wrote:a friend helped me out i figured thanx
2003 Accord K24a4 - TSX 6 SPD - 4.7 FD - Greddy Turbo - 550cc - KPRO
