Help please: Datalog strange CAM and IGN
gigaCTR
Post by gigaCTR »
hello all,
i found some strange things in my datalog:
***updated: not only in mine, looks generally!***
Is the CAM dropping to zero at low RMP (idle)
even when CAMCMD is higher?
Is the IGN dropping lower as in tables at low RMP (idle)
even when there is no command to redard in parameters?
any help appreciated!
thank you!
You have to post your calibration for anyone to be able to see what is going on.
gigaCTR
Post by gigaCTR »
made a general question, found that behavour in most datalogs.
thank you for looking!
The cam normally rotates to 0 degress at idle.
For ignition, see 'ignition controlled idle'.
gigaCTR
Post by gigaCTR »
Thank you!
