s300: Idle in colum 3 and 4
Posted: Mon Apr 26, 2010 8:03 pm
Hey i just turned my car on after 400 miles of na driving.
after i hooked up the turbo kit and all the components, i turned the car on and plugged in the s300 to my laptop using smanager 1.4.5 vers.
My idle when data logging is at 1,100 even when its cold start and before it was at almost 2 and would go down. idle is also in colum 3 and 4 instead of 1 and 2. My vaccum pressure is at 20 to 21.
I have a aem wideband hooked up but not to the ecu and on the wideband it reads about 12ish to 13 when i turn it on and then goes about 15.1 to 16 when warmed up.
my set up is.
b16 81.25 srp pistons 9-1comp
crower rods
itr cams
slight port n polished head
spooling performance 3" down pipe
spooling manifold with garrett 60-1 t3 .70 a/r intake and .63 exhaust
2.5 int piping with greddy pov
38mm wasgate
1000cc rc injectors
walbro fuel pump 255hp
3bar map sensor gm with vaccum running into the intakemanifold instead of throttle body.
any idea whats causing the idle to be at 3 n 4 I thought 20 vaccum is good enough.
Turbo is not spinning at idle either idk why juarnal bearing. it spinns when you turn it on and give it a little gas.
any ideas.. I go an appointment to go to tune this friday but i would like to fix this before i get there.
my set up is.
crower rods
itr cams
38mm wasgate
1000cc rc injectors
