injector dead times changing with resistor box??
NauTech
Post by NauTech »
i am trying to get the injectors dead time calibration right (opening times/battery voltage compensation in kpro)
and i would like to know if anybody has already done this and could have some tested numbers
cause i have seen the site http://injector-rehab.com/kbse/lag.htm but i remember reading somewhere about hondata (the admin user on here) saying that it was not really accurate ...
and also if i am using a honda oem resistor box/ aftermarket resistor box(12.4ohm resistance) could it change the injectors opening times? therefore fucking all the ms numbers in those charts... needing someone who did a test with those injectors and honda resistor box to get the real accurate numbers? cause my idle is a little weird i tried some 500 rochester and its straight perfect like the stock ones so i know its only the injectors opening times being the problem with the 1600cc's
injectors i am using are bosch 1600cc 0280150846
and i have an aftermarket 12.4 ohm resistor box but i could change it to an honda oem resistor box if somebody has some opening times tested with this resistor box it would be a pleasure to change it if it is working great :)
thank you
