"Out of memory while expanding memory stream"
engjoo
Post by engjoo »
I was viewing back and forth several (8-10) different datalogs (averaging 2-5M in size) when I enounter this pop up window with the following message:
I am runing windows Vista 32bit and FP 1.1.4.7
It is a memory limitation of 32 bit Windows. We're aware of this and are looking for a work-around.
engjoo
Post by engjoo »
Hondata wrote:It is a memory limitation of 32 bit Windows. We're aware of this and are looking for a work-around.
Does it mean I will not see this problem with a Win7 64bit ?
Unfortunately it would have the same problem in 64 bit Windows, where Windows limits the virtual memory size of each process.
200HP EP
Post by 200HP EP »
So what is the maximum datalog time we can save on windows?
It varies with the datalogging rate. Somewhere between 90 and 120 minutes.
TL-Slow
Re: "Out of memory while expanding memory stream"
Post by TL-Slow »
tried to download a calibration on Vault and came across this today
