Closed Loop Threshold
Posted: Wed Apr 14, 2010 8:32 am
by VT-Doo
Standard maps within KManager have the Closed Loop threshold set to 80kPa.
I read one of Hondata's posts stating 70kPa is a better option.
I'm curious to see what others have set theirs to including a little insight from the moderators.
The reason for this is because I feel the car will enter Open Loop with what seems like little load on the engine.
Cheers,
Posted: Wed Apr 14, 2010 8:52 am
I find that 80-85 kPa works well.
Posted: Wed Apr 14, 2010 2:36 pm
by Floppie
Personally I just run open loop :)
Posted: Fri Apr 16, 2010 5:24 am
by VT-Doo
Thanks,
I've bumped it up to 80 for now, I'll see how I get on and report back.
Posted: Tue Jul 27, 2010 5:21 pm
by Tsx536
Would a map of 90 kpa be too high for the closed loop max?
My main concern is that we need to tune for a richer mixture as the manifold pressure increases. As the pressure goes up, we want to tune the AF ratio closer to 13.0-13.5 for the NA tables.
So at what point do we need to tune towards 13.0-13.5 instead of 14.7?
How much pressure is the max that is safe to run at an AF ratio of 14.7?
Posted: Thu Jul 29, 2010 1:41 pm
by Floppie
If you pull enough ignition out of it, you can go as high as you want at 14.7 - you're going to be losing a fair amount of power though. Personally, if you're going to use closed loop, I'd say go with what Hondata recommends for the max load setting.
Posted: Mon Nov 15, 2010 5:55 pm
by tiger
What is the actual max MAP value for closed loop? Does it switch to open loop at some point regardless of what value you put in there?
Posted: Wed Nov 17, 2010 1:50 pm
by The Spectacle
tiger wrote:What is the actual max MAP value for closed loop? Does it switch to open loop at some point regardless of what value you put in there?
KPA MAP
5 -14
10 -13.2
15 -12.5
20 -11.8
25 -11
30 -10.3
35 -9.6
40 -8.8
45 -8.1
50 -7.4
55 -6.6
60 -5.9
65 -5.1
70 -4.4
75 -3.7
80 -2.9
85 -2.2
90 -1.5
95 -0.7
100 0
