TSX idle dual k-pro
sass
TSX idle dual k-pro
Post by sass »
Hello.
I use the “dial k-pro” on the TSX. I want to install 1000ss injectors for my turbo project.
I know that I will have a problem with motor on the idle speed.
Maybe I have a solution to this problem.
I wish to know your opinion if my solution to use idle valve from RSX for TSX throtle would work???
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
You won't know until you try.
