06 TSX Calibration
Slip_Angle
06 TSX Calibration
Post by Slip_Angle »
Is there a calibration for the 06+ K24a2? Even direction on what cam angles the 06 K24a2 likes for closed and open loop would be a great start.
I just installed the 06 Intake cam on my 04 K24a2 and A/F is all over the place now. I didn't think a cam would make things so different but I don't want to tune A/F not knowing what good cam angles are for closed loop.
Thanks!
tiger
Post by tiger »
Hey slip angle,
Do you have a new map for the 06 tsx intake cam? I am about to switch to the same intake cam on my k24a2. I am running your old map (adjusted for A/F of course) you uploaded and its by far the best map I've used.
keto06
Post by keto06 »
I tuned 1 06 k24a2 but it was in an RSX and had the stock gears unmodified...
Slip_Angle
tiger wrote:Hey slip angle,
Sure, no problem. It's not complete yet because my O2 sensor went on me and I'm still doing a bit of work on cam angles but give it a try..
tiger
Post by tiger »
Slip_Angle wrote: Sure, no problem. It's not complete yet because my O2 sensor went on me and I'm still doing a bit of work on cam angles but give it a try..
Awesome thanks man. Keep me posted on how your map develops. I try tuning things like cam angles and usually just make a mess of things.
keto06 wrote:I tuned 1 06 k24a2 but it was in an RSX and had the stock gears unmodified...
I will have the 50* VTC on the 06 Intake Cam.
rpmr6
Post by rpmr6 »
I did a search but thought this may be faster if i just ask. would you happen to have a copy of this cal. ? as i have a k24a2 in a rsx base with stock gears and rbc/type s TB Injen cold air and header into a greddy cat back sys. But i have no cat on car (bought used so not sure on header as it came on the car could be a megan? (4x2x1)
Thanks for your time i just got the car running and have to get it to drive straight before i can do any kind of pulls :) (hope this week get it in for alignment)
tiger
Post by tiger »
Hey Slip Angle,
Just wondering if you've had a chance to finish your map?
Slip_Angle
tiger wrote:Hey Slip Angle,
Sure, I've attached the latest version. I changed cruise to 25* VTC and modified some of the open loop angles. Fine tuned ignition for any knocking and added 10* IGN retard at 130 degrees IAT.
Let me know how it works for your car.
tiger
Post by tiger »
Great, I will do some tests tonight. I used the one you previously posted and it worked great. Once it moved onto the high cam map, it really pulled. I just wished it didn't have to stay on the low cam for so long. I actually let an instructor at a autox school drive my car and he said the acceleration was nuts so yeah, the map was working great.
db8typer
Nice
Post by db8typer »
How is this map working out?
HONDATA FTW
tiger
Post by tiger »
Sorry I don't get updates for this thread. The map really worked well. I don't use it anymore as I am boosted now.
