2006 ecu used in 2002 s2000
Posted: Wed Mar 31, 2010 6:49 pm
by S2000
New guy with a question. If I were to replace my 2002 s2000 ecu with a newer 2006 s2000 ecu and change to the 2006 sensors I should be able to run flash pro? I am just looking for options. I may have access to a 2006 ecu and was hoping this may work.
Posted: Thu Apr 01, 2010 8:20 am
It's a little more compilcated than that. The 06 ECU requires the 06 harness, DBW throttle body, DBW controller, DBW throttle pedal, 3 wire crank and cam sensors - basically you'd need to take everything out of an 06 vehicle and put it in yours so that you have an 06 vehicle in an 02 shell. Once you did that the FlashPro would work.
