Uping the boost
Posted: Fri Mar 26, 2010 1:44 pm
by burmese434
Maybe it just the boost controller but not sure..I'm running 13-14psi and when I put the boost controller as soon as it goes over 14psi it cuts out so not sure what's going on. Lsvtec turbo 2.0l and s300. The car is not going lean or nothing when this happens and I have 1000cc injectors to with walbro pump will upload my tune here later on
Posted: Fri Mar 26, 2010 8:00 pm
by burmese434
Here's the tune
Posted: Sat Mar 27, 2010 9:58 am
by El Verdugo
Is the fuel pressure staying where is supposed to at that boost level?
Also is there any CEL that are on since you do have cut boost if CEL is on in the Parameters.
You should also attach a datalog to see how the car behaves when this condition happens.
Posted: Sat Mar 27, 2010 6:43 pm
by Martian
Your boost cut is set at 15psi. Thats why you are having issues. You want to up the boost, then you need to also up the boost cut.
Posted: Sat Mar 27, 2010 6:48 pm
by burmese434
Ya i just seen that lettery 5mins ago lol thanks
Posted: Sun Mar 28, 2010 7:45 am
by El Verdugo
I am glad u guys seen that since when i opened the kalibration I saw the hot boost cut set at 28psi.
